Weird Arctic Preview of a smooth surface in Rhino 6 and 7
Hi everybody,
I have some weird Arctic preview problems. The surface that you see here is actually smooth as you can see on the shaded preview window, however, the arctic preview and also a preview with an environmental map show some weird triangulations and I see shadows that shouldn’t be there.
Does anybody have a fix for this?
I also have problems with a preview of the edges of surfaces that are split by the same curved edge. It shows a weird hole in the geometry where the edges touch. I hope this is a somehow understandable explanation of the problem.
I guess it has something to do with this mesh preview that rhino uses, but still, is it possible to fine-tune the meshing so I get a smoother preview?
I have the latest drivers from Nvidia, Running RTX 2070 Super and also 8 Core Ryzen 7
Here also some pictures of the problem:
The problem with the edges touching but the surface still looks jagged
This is a Vray interactive preview, still the same problem
Thanks in advance!
Render Mesh can be adjusted in Options>Mesh
more info here
https://wiki.mcneel.com/rhino/meshfaqdetails
Thank you very much!
