Weaverbird Missing Plugins
Hi everyone,
I tried downloading Weaverbird from the https://www.giuliopiacentino.com but the plugin wouldnt install. Apparently there are 8 unrecognized objects and when I tried to install them, they cant be found. I have attatched the error here!
Screenshot (115)|690x460
The SSL secure channel is something @will knows more about. It’s a momentary problem with server communication, I hope. Let’s hear from Will himself.
Thanks for the reply! Still no luck but I cant wait to use Weaverbird in my design!
@rpatanav, try opening the attached Grasshopper file before opening the weaverbird file.
tls12_fix.gh (3.0 KB)
Can you run the _SystemInfo command and send the result? I’m curious to know which third-party Rhino plug-ins you have installed as I think one of them might be triggering this problem.
Hello @Will I’ve got exaclty the same problem, I dont know how to fix it. ( I have R6)
I opened that file, but I don’t know what I have to do, thanks!
Hi Eva -
That’s expected behavior with that ancient (and cracked) version of Rhino.
Hi @wim ,
Seems it was not that the problem though, I fixed it, thank you. :slightly_smiling_face:
