I am currently trying to install weaverbird for grasshopper but every time I run the package restore, it gives me this error. Is there any way to fix this? I am running Rhino 7.
Hi -
I’m guessing you are running an old version of Rhino. Run the Rhino SystemInfo
command and copy-paste the result here.
I thought the same so I tried updating but that also did not work. Here is the system info:
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Educational Lab License, build 2021-09-13
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Unplugged [83% battery remaining] ~68 minutes left
Primary display: Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 4-7-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P4200 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 7-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.41
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2021
Driver Version: 30.0.14.7141
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\James\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
Hi -
I would try disabling this plug-in and restarting Rhino.
Apart from that, there’s a file in the following post that you could try:
The file from the attached forum worked. Thank you so much!
Hello @wim I have the same problem, but I don’t know what to do, That file doesn’t work to me I think, btw I’m using Rhino on an old pc, if yo want, here is the data that appears on my screen:
Rhino 6 SR25 2020-4-23 (Rhino 6, 6.25.20114.05271, Git hash:master @ f35d7ded15ec317635ced435d8df84327397038d)
License type: Comercial, revisiĂłn 2020-04-23
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 2.9Gb)
Machine name: DESKTOP-AHH1537
Non-hybrid graphics.
Primary display and OpenGL: Intel(R) HD Graphics (Intel) Memory: 1GB, Driver date: 11-26-2012 (M-D-Y). OpenGL Ver: 1.1.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: No compatible
Driver Date: 11-26-2012
Driver Version: 8.15.10.2900
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1272084 KB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.25.20114.5271
Hi Jony -
You are not only using an old computer but also an old version of Rhino 6. Please update to the current version.
Please try to find an updated driver for your Intel GPU - open the Rhino Notifications
panel and follow the links to the page where you can find driver downloads.
At this point, the drivers are not installed at all and Windows is doing all the drawing. You can’t really use Rhino in this state.
hello @wim I have the exact same problem installing weaverbird and I tried y to fix it with the file from the forum but it didn’t work, is there anything else I can do to fix this problem?? thanks.
here is the Rhino_systemInfo:
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type:Educational Lab License, build 2020-12-08
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 24Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-8-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti with Max-Q Design (NVidia) Memory: 6GB, Driver date: 5-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.78
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-5-2022
Driver Version: 30.0.15.1278
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
Hi Santiago -
Yes, that is not going to work.
The current release of Rhino 7 is SR20. You will need to update your Rhino version.
Hello @wim I have the same problem with rhino 7
But apparently everything is going normally, however so far I have not been able to install Weaverbird.
That is System Information
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Corporate, build 2022-10-09
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 10-12-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 522.30
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 10-12-2022
Driver Version: 31.0.15.2230
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22282.13001
Can you Help me?
Thanks!
Hi José -
For what it’s worth, you are also running a cracked version of Rhino.
In a different thread earlier today, another user was able to use the PackageManager
Hello @wim
I have installed Rhino 7 today and tried to install Weaverbird but I am not able to install the plugin with the Grasshopper file.
it says failed
my system info
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Evaluation, build 2023-02-27
Expires on: 2023-07-11
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
C:\Users\royan\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.13.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Hi Ethan -
Check and see if temporarily disabling your firewall allows you to get access. If you are on a network that is controlled by others, you might need to try this on a different network.
