WB Mesh from lines misunderstand - valence threshold
I am struggling with wb mesh from lines component. Not really understanding how it works I think. I am only starting with WeaveBird.
I need to transform a mesh I’ve constructed to have a parametrical study of strength repartition. Anyway, I end with a tree structure of the lines, with I need to transform in a mesh composant, making Karamba analysis easier.
For curious, it is base on C30 grid shell of The Hague.
However, I thought maximum valence would be the value to adjust for proximity of points to be considered the same. At 12.5, the NakedPoints / ClothedPoints distinctions either misses a row, or get everything. I need only the
I was looking for the code of the function, but I couldn’t find it.
Here are some pictures, and the gh file (the generation of the geometry is included, definitely not optimised, but I ended up having a parametric model that works !)
C30_V1.gh (56.8 KB)
Thanks for any advice !
You could also use the native Mesh.CreateFromLines RhinoCommon method instead (i.e. in a script component). The four perimeter lines probably need to be split though:
260219_MesFromLines_00.gh (11.1 KB)
And welcome on board :slight_smile:
