Wavy Surface
I want to make a surface like this.
I managed to make these baselines, how can I convert them to a surface in waves?
Hi
If using grasshopper to achieve this is an option you can search for similar topics : Circular wave on a surface - Grasshopper
But if you want to make it by " hand " first : make some random moves in " z " direction to have a height difference, and then use " patch "
  • another way to do it in rhino,is moving points of surface.
Hello
it could be better you post a file because, I think you don’t use the good approach.
Most of the times you just have to move the mesh or surface point according to a weight.
and many others discussions
I stumbled upon your file in one of the forum threads. It does exactly what I need but it has mathematical formulas that I don’t understand well. I’m looking for other methods to achieve a similar result.
Noise or reaction diffusion could help
how you made this first
