Hey Guys,
in a study project I am trying to build a structure as modulare as possible. I was already given the Hint that Wasp and in adition Wasp++ are most likely to be very helpful tools. So i started with using the tutorial videos but i have a problem with stating the connection. I always get a failure. The Wall Elements are based on a rectangle which is combined into a Mesh which then connects as a Geometry to the Wasp Copnnection from Direction Element. Center Point is the actual centerpoint generated by using diagonals from the edges of the rectangle. Intersection is the middle Point. Also the upvote has been generated as a curve converted from a line which goes from the middle Point to the edge of the rectangle.
Where is my thinking failure, i really tried hard to fix the error. Thanks in Advance, you can see the picture below.
