Wasp Grammer Rules
I’m working on to create Danzer geometry.
I wish to apply two rules simultaneously in wasp.
In Image, have defined 2 points on a segment of Triangle, so as to make a reverse connection.
Point 0 connects with Point 1 &
Point 1 connects with 0 .
Also, are there more rules (other than defined in tutorial) to control the connections in wasp.
WASP EXPERIMENTAL GRAMMER NEW.gh (23.9 KB)
Move to Grasshopper category so it will be seen.
Hii, John, Thanks for such a quick response. I am pretty new to Grasshopper can you please elaborate or suggest some material to look at.
Hey @vikas.athwani9999,
Have you tried the Wasp forum?
– Dale
danzer through Vertex_Edge_Connections.gh (38.2 KB)
This should get you started!
Now it’s up to you to refine the rules and connections to make it a danzer tiling.
You should note that Wasp needs a three-dimensional base geometry to do collision tests!
danzer through Vertex_Edge_Connections 2.gh (26.1 KB)
