Glad I could help! I’ll try my best to give some direction, but first some notes (I’ve been told I’m a bit of an old man at heart, so I apologize for any unwarranted advice or waffling).
It would be useful to know what you’re trying to accomplish with this project before we can offer more help. The reason why is because sometimes a tool is simply not capable of accomplishing a task, but we can never point out when someone is using the wrong tool if we don’t know what the actual task is. As an example, the tetrahedral honeycomb you shared here can be accomplished without Wasp.
For an aggregation that encloses a dome, you cannot use a single part to encapsulate the dome without gaps unless you are emulating Platonic or Archimedean solids, at which point the rules are mathematically defined and Wasp becomes unnecessary again.
I ask this because the uneven chains, variable region density, and 3d boundaries you want to avoid are features of aggregations and a byproduct of how they are formed. Wasp selects from a list of possible arrangements at random, so chains like the one you see occur when Wasp repeats a sequence of selections in the same area. The same follows for the dense regions: more sockets for adding parts are in the dense regions, so Wasp is more likely to add parts there, making them denser. The boundaries are not strict, but rather help guide the aggregation - it is not possible to restrict Wasp to “one layer”, because Wasp only sees possible arrangements and how likely they are to occur. If you want these features removed, you will need to strictly define your rules and your geometry so Wasp chooses the arrangements you want, but at that point they might as well not be aggregations.
As an example, I generated this structure without Wasp, and it seems to do what you’re asking for (not entirely sure though):
aspiring_facet_dome_01.3dm (2.9 MB)
aspiring_facet_dome_01.gh (11.7 KB)
The only non-native component I used is the MeshDual component, which you can find here.
If you still want to go with the Wasp route, your field currently prioritizes the faces of the inflated dome due to Pull. You should instead define a dome surface then set the values of each field point to be based on SrfCP, with some cutoff to define thickness. To reduce the chains and bald regions, I would recommend rotating the planes from 0 to 240 deg, not from 90 to 270 deg. This should cause the form to “ball up” more and make it more likely to form closed regions.
Please let me know if you have any questions.
