I decided to try the new rhino 8 yesterday but have a big issue with view modes. I want to catch the same view quality as Rhino 7. The images are taken with the default view settings.
Could anyone help me?
Hi Joshept -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Evaluation, build 2024-12-10
License details: Cloud Zoo
Expires on: 2025-03-12
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 15GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 6-10-2020 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated accelerated graphics device with 3 adapter port(s)
Primary OpenGL: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 6-10-2020 (M-D-Y). OpenGL Ver: 1.1.0
Secondary graphics devices.
Radeon RX 5500M (AMD) Memory: 4GB, Driver date: 9-26-2024 (M-D-Y).
> Integrated accelerated graphics device with 2 adapter port(s)
- This device is not being used
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
Your laptop graphics drivers are over 4 years old, it’s using generic Microsoft OpenGl that can’t do anything, and the hardware is not really adequate for Rhino 8…or 7 for that matter.
Oh, and it’s not actually using your RX 5500M. Man laptops are just garbage.
Make sure this is your primary GPU
You are right, I formatted my computer and installed Rhino 8 without any driver updates. Now, I am going to update my driver quickly. I will write here the result after it.
Actually, I graduated with this garbage laptop using rhino 7 without any issues.
Luckily your work didn’t challenge Rhino 7 on your laptop. You will undoubtedly find that Rhino 8 can’t do as much successfully since it’s hardware requirements increased noticeably.
I solved the problem by updating my graphics card’s driver. Thank you for all.
