I can get the skin in as material wall, but it really does not do me any good because I cannot apply any additional data to it.
I have modelled the mass in Revit using points that I triangulated, and it takes the wall by face command. I wanted to use Rhino’s superior modelling to generate the mass. My hope was that there was a way to generate the building envelope using a Brep and apply the wall type to that.
There is a lot going on in this model, it is hard to determine which strategy to use.
If the geometry is coming in as a mesh, then that means Revit is rejecting the BREP. So determining why that is the first issue to solve. I expect the original cone shape need to be hit with the rebuild command to make it a Degree 3 surface in both directions. Currently Revit is struggling with Degree 2 surfaces. We are looking into that.
The Mass must be part of a Family/Type/Instance/Form, not a Directshape. It seems like a subtle difference, but it is one of the most important distinctions to understand with Revit. Here is a guide on creating real Form geometry: Rhino.Inside®.Revit
