RIR Sending Rhino BRep as Mass Family to Revit
Hello! I’ve been trying to send an extruded planar curve as a BRep to revit as a newly created family, but when I try to insert an instance using ByLocation, I get the error ‘1. Type ‘wall 45 : wall 45’ is a work plane-based type.
Consider use ‘Add Component (Work Plane)’ component.’. I’ve set up the family as a generic model family, based on this post (Wall by Face from mass generated in Rhino - #44 by bbalbastre). Any help is much appreciated :slight_smile:
Try this workflow:
