Update:
I got the Unknown command: -_
I guess the double quotes is fixed, but what is the problem now?
Update:
Yeah it works. Thank you very much Travis
Great news! I think the copy paste formatting is what was messing things up a bit for you.
Hi, what about tackling the same problem with VrayNext (update1) for Rhino6 ?
I have moved on from Chaos group a few years ago.
@Trav at McNeel
or
at Chaos Group
Would be the ones that could help you with this PlugIn issue.
Any update on this tthanks. I am having the same issue with Vray5 for Rhino6
This shouldn’t be a problem in V-Ray Next / 5.
I assume the issue with rendering animation beyond the first frame only occurs with a specific project?
Could you please open it, use the menu V-Ray > Pack Project and then submit the resulting archive for investigation by visiting https://www.chaosgroup.com/help/contact/support/scene#options ?
Kind regards,
Peter
Hi!
I have the same problem
See attachment
Hi! Friends
I understood we have to wait for the final update of Bongo 3.0
Meanwhile I work with Rhino renderer
[87502 Animation - YouTube]
(87502 Animation - YouTube)
You can see the result
I hope it’s OK if I’m asking to follow me on my social media
Login • Instagram
Redirecting...
The problem with Bongo and Rhino render that you can’t set the denoiser before rendering the video. it’s need to be done for each frame
Thanks
Meir
You should save the post effects as document settings, it’ll stick also between frames.
