The raw mesh is too heavy to thicken it and and then do mesh to nurbs and I need to smooth out the surface first anyway as the resulting waffle does not need to be as precise. So I am following this https://www.youtube.com/watch?v=4zFmlC1uGS4 to convert the mesh to nurbs surface initially and then input into a waffle script such as this one which is for a starting brep surface Waffle Structure | Parametric House
ISSUE (although any advice/recommendation on the method I am using is appreciated)
My problem is that it seems because the contour curves have ‘holes’ in as in they stop and start around the gaps in the mesh so the loft is not working. I presume the curve inputs need aligning/ordering or do I have to do multiple lofts and join?
