Wacom tablet right click not working in rhino only
I’m using an Intuos Pro M on Windows 10 running Rhino 5 and 6.
Wacom drivers / firmware are up to date. Rhino is up to date.
Rhino will not receive right click input from any button on the pen. Other click types work. Right click works in other programs and when navigating windows, so it’s a Rhino-specific problem.
This inhibits me from using the tablet in Rhino, which is essential to my work.
hi @heinzler,
Does this help with anything?
@Jarek thank you. unchecking “use windows ink” solved it.
Great. It’s a bit weird - you may notice other software misbehave with this change. Over here when unchecked, Photoshop pressure stops working. So need to flipflop between this depending on what software is used.
you can customize behaviors according the software you’re using.
also this option can be software dependant.
give it a try, it’s worth the 30 seconds required to configure it :wink:
