Today, after five years of honorable service, my Wacom tablet left me …
Using the tablet as the main system even in Rhino.
But come to the point. The operation, after adjusting the settings is as above, except for one thing … one of the 2 pen buttons s set as the right button and it works on all the options, but if I try to do desro button on an icon dual controls (for example explode to extract the surfaces) is wrong and the command is implemented as a simple click. Some idea?
edit: as a temporary solution I replaced the right button with ctrl + left key modifier.
Software information
Software versions
Rhinoceros version: 5.3 WIP (5D92w)
IronPython version: 5.1.2015.131
Language: it (MacOS default)
OS X version: Versione 10.11.6 (Build 15G1108)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Bluetooth USB Host Controller
Inateck USB to SATA3 Bridge: Inateck Generic USB Device
Lexar: WorkflowD512
GenesysLogic: USB3.0 Hub
Wacom Co.,Ltd.: Intuos PS
3Dconnexion: SpaceMouse Pro
Bluetooth devices
Apple: Apple Wireless Keyboard
Apple: Apple Wireless Trackpad
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-10.10.14 310.42.25f02
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bit
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: Yes
Is the issue that your right click pen button is acting like a left click over icons that have LMB or RMB commands? Are you still having this issue as well?
Yes the problem remained, but I adopted the following strategy. 1) I set the right button on the pen. 2) I added to the pop up menu functions that need the right key (extract surfaces , cancels cutting, 3D wheel)
Also sometimes you can not select objects, you need to press a button and then everything starts to work
Computer hardware
Hardware model: MacBookPro6,2
Processor: Intel Core i7 CPU M 620 @ 2.67GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel HD Graphics 288 MB
Memory: 288 MB
Screen size: 1440 x 900
Displays: Color LCD (111dpi 1x)
USB devices
Apple Computer, Inc.: IR Receiver
Apple Inc.: Built-in iSight
Apple: Card Reader
Apple Inc.: Apple Internal Keyboard / Trackpad
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-10.0.51
Render version: 2.1
Maximum texture size: 8192 x 8192
Z-buffer depth: 24 bits
Maximum viewport size: 8192 x 8192
Use texture compression: No
Update.
Often do not work the shift and cmd keys (in combined use WACOM, 3D connexion and keyboard. Sometimes the objects are selected and can only be deselected with esc. Leaving Rhino everything starts to work … but only for a few minutes . This happens both with commercial Rhino with WIP in the period of greatest work of the year. Really frustrating.
