Wacom Cintiq or Intuos with Rhino
I have a XP-Pen Artist 15.6 Pro Drawing Tablet with Screen ( the Upgraded version of Artist 15.6 ).it has a 15.6-inch display with full HD resolution (1,920 x 1,080), It can produce 88 per cent of the NTSC colour palette . it’s stylus support 8, 192 pressure levels and tilt recognition. it was a cheaper alternative to wacon cintiq tablet . more details: https://www.xp-pen.com/goods/show/id/394.html
a Screen DrawingTablet is not a “must have” for Rhino.
My Artist 15.6 Pro graphics Display is really useful for painting and sculpting purposes.
But on a Screen Drawing Tablet Your hand often covers the screen, so You don’t see what happens on it.
I dont’t like working directly on the screen when I’m using Rhino.
I have used Wacom Intuos before. It is small but perfect for my needs at the time, but now for the other.
I just upgraded to win 10 from 7. I had my Wacom pen with Intuos pro working great in win 7 but now finding a glitch in win 10 that I haven’t found the solution for yet. In 7 the lower button of the pen would register as a right click to end a line or re-invoke a command. I now find this not to be the case in running Rhino 6 in Win 10. So far everything else seems to work.
Any quick advise? And TIA for your time :slight_smile:
Gary D
Hi Gary,
Does this help?
Hey Jarek, that seems like a logical answer but the driver panel, and I assume you mean in device manager?? doesn’t have a calibration tab.
G
it should be in the Wacom Tablet Properties, no?
OK, On my older Intuos small, the command was in another location but your suggestion was very useful in helping me to find it. Thank you!! Resolved!
G
It would be great if the gestures could be set to execute a right mouse drag to navigate in the grasshopper canvas. On a two screen setup, the tablet would be set to one screen only. This could help reduce distances moving the mouse left and right from one screen to the other.
If you have the latest Intuos Pro, you should really try the Pro Pen 3D. The buttons are pre-programmed for Zoom, Pan and Orbit, but you don’t lose the right click option either. Keep this string going please. Definitely disable Ink on the Pen/calibrate tab as well (win only). It makes it much more usable.
That’s nice, unfortunately my Intuos Pro is just PTH-651 and not compatible with the Pro Pen 3D :pensive:
Are there other benefits for the 3D pen apart from the view manipulation options over the regular pen?
Those that are using a 3DConnextion, will have no use for these navigation/zoom options in Rhino. would be interesting though for other Apps that do not support 3DConnextion [like Zbrush]
I’ts 100$ in the US, so at least 150$ here.
Akash
anyone having a double click issue with the wacom intuos? i have a intuos 4.
Hello
Does xp pen model work will with rhino ?
