I have geometry in Rhino with custom mapped textures to look like wood beams. When I try to render from Grashopper using the VRay Render and Render in Project components, the custom mapping disappears. I was doing this a few months ago without issue, and I suspect it may have started with a recent update, but if there is something I am missing, please let me know… Thanks!
Vray 5.10.06
Rhino 7 SR9
(7.9.21222.15001, 2021-08-10)
Hello, Oliver Bucklin!
Thank you for your report! The issue is confirmed and logged.
The V-Ray for Rhino dev team will investigate it and find a solution as soon as possible.
Kind regards,
Emiliya Docheva-Dimitrova
V-Ray for Rhino QA
Hello!
The developer`s investigation about the described case led to the following conclusion: Rhino geometry texture mapping persists in Grasshopper only if the Rhino geometry is mesh. In case the Rhino geometry is nurb, its mapping will not persist in Grasshopper. The reason about it is described here Render in Grasshopper removes texture mapping - Chaos Forums
Kind regards,
V-Ray for Rhino QA
