I’m going through VRAY 3.X Tutorials using Rhino 7 and VRAY NEXT. The Lesson 2 section on Proxy/Export.
When I Export the VRAY Proxy object to the VRMesh, I do not get the resulting VRAY Multi-Material that is supposed to appear in the Asset Editor as the tutorial tells you will happen. Am I doing something wrong, or is that a change in NEXT from VRAY 3.x?
Thanks,
Thomas
