It seems that V-Ray doesn’t apply a material to OBJ imported block instances. Rhino model block instances work perfectly fine.
But how do you apply a material to an OBJ block instance with V-Ray??
Vray material not able to aaply on OBJ block instances
Hello - does BlockEdit
let you do what you need? (i.e. apply the material to the mesh from within BlockEdit
, or set the material assignment to ‘By Parent’ within BlockEdit
It says only 3dm files can be edited.
Yeah, so these are linked blocks - the only thing to try would be to embed the blocks, as far as I know. (BlockManager
Oh okay. It would significantly make the file size heavy
I’ll do that.
