I found an issue with texture mapping wich work well in the rhino viewport but goes wrong when render with VRAY.
If I explode the visualarq object, rendering works fine again (but I lose all their visualarq properties). This problem occurs only on VisualARQ object (like walls…)
cf.image below, the backround object is just a box not a visualARQ wall.
I’ve found that thread on the vray forum wich suppose that it’s a vray6 bug Texture issue - Chaos Forums
Using Vray 6.00.01
Here is the system info
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Commerciale, build 2022-11-22
License details: Cloud Zoo
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 3050 Laptop GPU (NVidia) Memory: 4GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\f.bessiere\Downloads\rhtogh\RhinoToGrassh opper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\f.bessiere\AppData\Roaming\McNeel\Rhinoce ros\packages\7.0\Walkie\4.14.0.0\Walkie.rhp “Walkie” 4.14.0.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7 .rhp “Karamba3DLicense”
C:\Users\f.bessiere\Downloads\blockeditnew20221115 \BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\f.bessiere\AppData\Roaming\McNeel\Rhinoce ros\packages\7.0\Bullant\1.6.1.0\bullant.rhp “bullant” 1.6.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
