Vray 3.6 not rendering materials
hey there,
I find problems to render with Vray 3.6 that it not render materials (you can see at the screenshot)
I try to render simple sphere and attach different materials (that come with Vray) and it’s no work, no glossy no opacity no bump.
any idea?
thanks
It seems that the Ice_Tea material is applied to the sphere, and it renders perfectly fine.
Hey Nikolay, thanks for your replay but i checked it twice and its not the Ice_tea. anyway if it was the ice tea it should be with opacity…
i tried to manage things and i found that my Vray has probably problem with the map texture and maybe it causes all the rest problems, its seems like i attach in the screenshot that the vray stretch the texture to all object, for example here the cube is about 5x5x7 meter! its not supposed to be rendered like this… i try to set any other map texture play with the U and the V but its not affect.
help :slight_smile:
