Hei guys,
i need help with my grasshopper definition.
I wanna make a Voronoi / Organic / Skeleton structure between the Curves. I tried to populate the curves but then i got no knot points between the curves. But also with Populate 3D the points are not exactly between the curves or “in the area” it´s a box around them.
Also Id like to build the lines between the curves in the closest points and not the end of one curve and the other end together.
I put here some example pictures what i have in mind.
Should I build the skeleton with exoskeleton or is another function more useful?
It would be really great if someone could help me or give me some tipps with that . ![]()
thank you very much and Greetings Maxi
Curves.3dm (28.5 KB)
Grasshopper file.gh (9.8 KB)
