Hello all,
somehow the built box in Rhino in Grasshopper is not recognized as a border box. Can someone help me with the script? Thanks a lot!
voronoi shelv.gh (7.0 KB)
voronoi shelv.3dm (192.0 KB)
Hello all,
Jenni, by hovering the mouse over an input, you can read what data type is required. The Region input requires a box. Your curved wall is convertedd into a box which is basically a bounding box. The boundary for the voronoi is again a box.
If you only want points inside your wall you better start with Populate Geometry. You can create a Boolean Intersection between the cells and your curved wall object.
Finally I’d suggest using multipipe. I added a quick solution to eliminate duplicate edges. The result is a closed SubD.
voronoi shelv.gh (19.7 KB)
