Voronoi cell joint
joint
I have a question about editing the joints of the Voronoi cell in the attached file. I want to create this structure, but the connections and joints are not suitable. How can I fix this installation?
also for every seed number I want to have proper join and connection.
thank you in advance
voronoi structure_q.gh (12.5 KB)
Can you explain why they are not suitable? What are the conditions for a suitable connection?
hi, since I want to print it in a large scale and I want to have a robust structure, in my model if you see the whole structure there are some separation between elements.
Are you using standard pipe?
Try multipipe
I use this component now, it looks better but for a few joint there are weird shape, I attach in this command box.
joint
voronoi structure_q.gh (13.2 KB)
Towards the middle he explains how to deal with that
The spikes occur when vertices are to close together. This needs to be cleaned up.
One approach:
in updated version of Topologizer there is no output for Line, it jest gives the points of curve, the approach must be a little different, I was unable to edit based on your shared file.
voronoi cell_edited_MCneel.gh (21.8 KB)
I edit my file following this video, but I don’t know how I adjust the distance between points, since in this video he used SubD while in my file I use box and populate 3d, if you have any hints, I will appreciate it. also there is separation
separation
between elements in structure.
In the video, watch from minute 7
It doesn’t matter.
if you check my file in my last reply, you can see that I applied all the process in the video from minute 7, but there is separation between some elements yet.
replacing these mesh components with Deconstruct Brep makes the missing connections pop-up
I didn’t investigate the reason for that, just followed the video instructions
thank you so much, my problem is fixed
much appreciated :slight_smile:
I’m not aware of an update for the topologizer.gha
Where did you download it from?
I guess this one
from this link:
This is my final file, I could edit the whole studs
and remove separation among them. Since I want to print this structure with 3d-printers, I want to remove some part of structure as shown in the picture, is it possible to remove these parts?
I’d like to simplify the design for easier printing.
voronoi cell_edited.gh (17.8 KB)
c775b77393a67a7069faf864e83c0cafd024ae60_2_690x401
increase the value of that slider until you’ve eliminated all the small faces
voronoi cell_edited v1.gh (40.5 KB)
much appreciated. it works :slight_smile:
