Greeting,
I have to calculate the 2d Voronoi based area for a selection of points using c# API. Is there any method or way to calculate Voronoi cells using API?
Hello
I am sure there is one in Grasshopper but I don’t think it is visible. Because there is just that !
https://developer.rhino3d.com/api/grasshopper/search.html?SearchText=voronoi
For rhino only see this way around
Thanks for the response i also found this: Grasshopper.Kernel.Geometry.Voronoi. I do not get how to use it though.
As there is no real documentation
… it is treasure hunt …
the most simple coud be to use that c#
https://www.codeproject.com/Tips/797123/Fast-Voronoi-Diagram-in-Csharp
I am using c# within visual studio for this specific project. in python we have access to nodes. it seams like in c# API we cannot use nodes.
Here the C# function from @AndersDeleuran
GhPythonCSharpVoronoi_.gh (55.8 KB)
private void RunScript(List<Point3d> nodePts, object y, ref object polylines)
//# Create a boundingbox and get its corners
BoundingBox bb = new BoundingBox(nodePts);
Vector3d d = bb.Diagonal;
double dl = d.Length;
double f = dl / 15;
bb.Inflate(f, f, f);
Point3d[] bbCorners = bb.GetCorners();
//# Create a list of nodes
Node2List nodes = new Node2List();
foreach(Point3d p in nodePts)
Node2 n = new Node2(p.X, p.Y);
nodes.Append(n);
//Create a list of outline nodes using the BB
Node2List outline = new Node2List();
foreach (Point3d p in bbCorners)
outline.Append(n);
//# Calculate the delaunay triangulation
var delaunay = Grasshopper.Kernel.Geometry.Delaunay.Solver.Solve_Connectivity(nodes, 0.1, false);
// # Calculate the voronoi diagram
var voronoi = Grasshopper.Kernel.Geometry.Voronoi.Solver.Solve_Connectivity(nodes, delaunay, outline);
//# Get polylines from the voronoi cells and return them to GH
List<Polyline> polys = new List<Polyline> ();
foreach( var c in voronoi)
Polyline pl = c.ToPolyline();
polys.Add(pl);
polylines = polys;
Thank you i think this will solve my problem. I’ll try it and share the result.
Worked like a charm. Thank you for your help and time
No problem I learned also, it could be useful for me in the future.
Hello! very usefull code! in case Iwanted to visualize the delaunay triangulation how could I do that?
