I have developed this complex and thin solid and I need to check its “waterproofness” before I extract the .STL file for the 3D Printer.
The attempt to build the volume with “create Volume” has not been succesfull.
Volumenkörpererzeugung in Bearbeitung… Esc drücken um abzubrechen
Volumenkörper konnte nicht erzeugt werden.
Therefore the surfaces have just been “verbunden” (German for bind) to each other.
Then the volume was checked with “visualize edges” : there was “no open or manningfaltig” edge.
After this check the command “Analysieren/Masseigenschaften/Volumen” usually delivers the desired answer. Unfortunately the response this time is:
Volumenberechnung in Bearbeitung… Esc drücken um abzubrechen
Volumen kann nicht berechnet werden."
What should I do next?
Am I making a mistake?
If so how do I discover which one?
Is this a bug in Rhino? I use R6 v26 on Windows64
Rhino 6 SR26 2020-5-26 (Rhino 6, 6.26.20147.06511,
2020-06-03T22:00:00Z
