Hi George,
I’m not aware of any tutorial that shows the connection between VA components and the ArchiCAD components in GH. But they are very similar in terms of how they work.
For example, in order to create a wall in VA you need a path curve and some extra data (height, alignment, style, etc…). And a similar data is required to create a wall with the ArchiCAD component. So you can deconstruct the VisualARQ wall and use its path curve and other data to generate a wall in ArchiCAD.
We have recently published a webinar where you can get a good understanding of how the VisualARQ components in GH work: https://youtu.be/kv5MbMToVDE
Hi George,
I think the “Layer” input in the ArchiCAD Wall component is referred to the layer where this wall is created (“Layer 01”, “Layer 02”, “Walls”, etc…) but it is not the wall “layer” component. You need to specify a “composite” wall in the “composite” input. And I’m not sure if you can create new ArchiCAD Composite walls in GH, so you could then obtain the information extracted from the VA Wall style to create it.
