Visualarq spiral stair issue
I’ve created a simple Visualarq spiral stair but if I change the style using the default styles, the steps are not more aligned with the walls.
Spiral stair issue in Visualarq.3dm (3.0 MB)
Thanks,
Roy
Hi @lopez, this seems to work fine on my end. If you edit a stair style and change its type to “balanced” you will get a rounded boundary of the tread slabs. If that’s still not working for you, can you attach a screenshot of the result you are getting?
What VisualARQ and Rhino versions are you using?
SpiralStair
Hi Francesc!
I’m using the last version of rhino 7 and Vsualarq.
The problem to me is that the only precise style is “Floating”. If I use “Balanced” the starting point of the stair is wrong. I send you some screenshots.
I see now the gap. I’ll report this to the development team.
thank you
