VisualArq Slow / Stalled on Plans creation
I am having important issues outputting basic plan views from my VisualArq model.
I have on the other hand been able to create sections and elevation views without problems but still no plans…
When creating plan views, once an input point is selected, the software keeps on calculating… without resulting drawing and without end… “creating graph… resolving curve endpoint…”
I left it computing for an hour… no result.
I rebooted the machine, tried again… no result.
Thanks in advance for your help!
Raymond_
Hi @raymond.gaetan,
I’ve seen this issue before. Seems to be related with many text objects with a very small text height, as VisualARQ needs to convert them to 2D curves in order to hide them, and when the text is too small, the Rhino function that convert texts to curves is very slow.
Can you please send me the file to visualarq@asuni.com so I can check what is going on?
Thanks,
Enric
Hi Enric,
Just sent you a WE TRANSFER link.
Raymond_
Solved!
Deleted small text objects…
Many thanks for the heads up!
Raymond_
Hi @Raymond,
Yes, I’ve checked the file and there are many text objects with a 0.006 height, which is very small. I’m going to add some code to ignore texts smaller than a tolerance.
Thanks,
Enric
@raymond.gaetan we have just published VisualARQ 2.6 that avoids this issue of plan views with tiny texts. VisualARQ 2 - Version 2.6 released
