Hello
Is it possibile to manage style of sectioned lines, which belong to an attached filed, as solid created in the current model?
I actually get two diffrent behaviour:
solid in the current model follow VA section style
solids inside the attached file just clip but don’t get any pattern, neither sectioned lines change appearence.
Thank you Alfonso
I try and as you said it works.
Do you know how can I set the default value of the “Section Attributes” panel?
In this way all new element would have the pattern I prefer.
