VisualARQ, Section View, Linetype change?
How can I determine the linetype on sectionView object’s sectioned objects?
By default it seems to give dashdot linetype to all objects that are cut.
I would like to change it to Continuous.
Hi @Toni_Osterlund,
You can use section attributes to define it: https://youtu.be/QjE66xW-Vig
Hi @alfmelbev
I need a little bit more info.
Section attributes of the Section View object. Still Dashdot.
Attributes of the Section style. Still Dashdot.
Attributes of the Section view style. Still Dashdot.
Section attributes of the block object that gets sectioned. Still Dashdot.
Section attributes of the geometry inside the block. Still Dashdot.
I ran out of ideas where to test…
Hi @Toni_Osterlund,
Please, send me your file here or to visualarq@asuni.com and I’ll check where the problem is.
@alfmelbev
File sent via email.
Hi @Toni_Osterlund,
The problem is that inside the Rhino block you have beams whose style section attributes linetype is defined as DashDot:
If you change it here your problem will be solved.
@alfmelbev
Great, thank you!
