VisualARQ crashes when update plan view
Hello, I just purchased VisualARQ and am experiencing the following problem: when I try to create or update a plan view, Rhino crashes. I am sharing the file. I look forward to your help—thanks!
Crashes When Updates Plan View.3dm (1.8 MB)
Hi @Pablo Míguez,
Thanks for sharing the file. We’ve reported the issue to our development team for further investigation.
We’ll get back to you as soon as we have more information.
Best,
Melissa
fellow VA user here. I noticed you are working, against Asuni recommendation, in a rhino template instead of VA one.
I did a quick test and recreated your project starting from a VA template and things are working so far, no crashes.
You can select File/New and from the template files select VisualARQ 3 - meters, or whatever units suit your project, and then recreate or copy paste from the file you shared the geometry and see how it goes.
Make sure you have you viewport visual style set to hidden, recommended style to see VA result.
best
alexandros.
Melissa, Alex, Thank you for your responses!
Indeed, now I am working in other file from VA template, and things are working well!
