Viewport toggle buttons
Im having a little problem i cant find an answer to anywhere. For some reason the standard toggle buttons on the bottom of the viewport are gone. It only says model and layout. I would like it to have buttons for top, front, right and perspective. Anyone know how to fix it?
Thanks!
Type in 4view and hit enter?
I can get the views on my screen but i cant get the 4 toggle buttons to appear on screen. I like to just have to click on them to switch between views when they are maximized. Now i have to use ctrl tab.
Welcome @metten.rutger
Use:
! _ViewportTabs _Toggle _Enter
No, it doesn’t work, i’ve tried it. It just hides or shows the two buttons that are allready there.
Hi @metten.rutger,
Right-click on the model tab and uncheck “Combine Model Tabs” (or something like that).
– Dale
Combined Model Tab
This setting persists across Rhino sessions.
That worked! Thanks alot for that!
Hi Metten, you can also go to View menu > Viewport layout > Show Viewport Tabs. It should solve your issue.
