Viewport Raytracing Issue (V. 8 SR17)
Since yesterday, I’ve been having a problem where the raytraced viewport is no longer working correctly (maybe since the update to SR17).
Environmet lighting/reflections, and diffused shadows are no longer displayed. Instead, just a “hard” black shadow, which always remains the same (any viewing angle).
This only occurs in raytraced viewport; the “real” rendering works as usual (see images).
I’m using Optix in the render settings, but I’m experiencing the same issue with CUDA.
I’ve already updated the Nvidia (RTX 4070) drivers.
System: Windows 11 Pro.
Does anyone have similar problems (or tips)?
Thanks in advance.
Andreas
You probably forgot to attach the images.
Does this mean using the _Render command (or the blue render icon)? If that is the case then you may have adjusted the Raytraced mode settings. Revert them to their defaults to see if it is any better.
Raytraced and Rhino Render use the same engine and should look the same, except when you have made changes to your Raytraced display mode settings - those don’t carry over to Rhino Render.
Thanks, i uploaded the missing images. Left shows the raytraced Viewport, right the Renderoutput.
I already tried a lot, (realtime/hardware Rendering Settings, CPU/CUDA/Optix, switch between Rhino Render / Legacy Render, Driver-Update, …) but nothing worked.
If you can share the 3dm file with the bottle. Also the output of the Rhino command _SystemInfo would be good to post here.
The image on the right is the Rendered display mode. It is not the same as Rhino Render or Raytraced.
Additionally:
Yes, the _render command is meant. I also did “Reset to Defaults” in Rendering Panel.
You should reset to defaults for the display mode, not the rendering settings: Tools > Options > Views > Raytraced → Reset to defaults.
I think it is not file dependent.
The same problem occurs with every file as soon as I switch to “Raytraced” in the viewport. All other modes (Rendered, Shaded, etc.) work.
Thanks for the tip. I think it’s working now!
(Although I don’t know how the RT settings were changed…)
Thanks very much again.
