_ViewCaptureToFile issues
Recently I’m having issues with view capture to file command. When taking with viewport resolution is all good, but when changing the scale and n of pixels the image somehow gets cut. Also, I happen to have same issues with taking with clipping plane (only one enabled and only one existing in the model) . Looks as if the clipping plane is cutting but the model is still protruding out
Hi, the issue I have is that when I scale, the whole image gets cut, it doesn’t screenshot the proper image and cuts the geometry
ned, 16. velj 2020. u 02:11 Fred_C via McNeel Forum mcneel@discoursemail.com napisao je:
