I have been attempting to use the viewcapturetofile command in Rhino 6. However, a sort of frame appears in the middle of the screen shot as shown in the image. What is the cause of this and how can I remove it?
Many thanks!
Many thanks!
Hi @yurkono,
Yes, I’m aware of some issues with ViewCapture + Skylight shadows. Do you think it would be possible for you to send me the model and the settings you used for doing the ViewCapture? I’d like to check if I have fixed this particular problem in my new ViewCapture code.
If you want to send the model confidentially, please use https://www.rhino3d.com/upload. You can set the recipient e-mail to david.eranen@mcneel.com
-David
Could you also paste the text from Rhino’s Help -> System Information...
Thanks,
-David
Rhino 6 SR7 2018-7-29 (Rhino 6, 6.7.18210.11281, Git hash:master @ f815aae129dfe2008152736625ca2dbd0036b29a)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Quadro M1200/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 411.81)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-16-2018
Driver Version: 24.21.14.1181
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.7.18210.11281
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin” 2.3.18250.752
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.7.18210.11281
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
Hi @yurkono ,
Could you try updating Rhino 6 to the latest version (Service Release 11)?
Go to Help -> Check for Updates...
. Then, click the Check now
link. This will allow you to download the latest version. I think it might fix your problem.
-David
Also here is the screenshot of my settings that I used. I actually updated Rhino 6 to the latest release not too long ago. But when I did, the option to check “Scale Drawing Thickness” disappeared. So that is why I went back to the previous version.
Do you remember if you tried the ViewCapture in SR11 despite the scale option not being there? Did the shadows look correct?
I’ve contacted two developers in regards to the missing “scale drawing thickness” option.
-David
David,
Yes, I still had the same issue with the viewcapture in SR11. I thought it had do with not having the ability to check “scale drawing thickness,” but that doesn’t seem to be the case.
Yu
was this ever solved? I have the same issue but the frame is horizontal in nature if yours is considered vertical in nature
