bobtato
November 11, 2023, 8:34pm
1
I hope I’m not derailing this topic, but FYI, I notice that when moving the camera with a 3DConnexion Spacemouse in Rhino 8, the rendered view doesn’t always update to the “static” version after it stops moving.
(This is 8.0.23304.09002 on an Intel/Iris MBP)
Gijs
(Gijs de Zwart)
November 12, 2023, 4:08pm
2
Hi @bobtato pls run _Systeminfo in Rhino and post back the results.
bobtato
November 13, 2023, 1:48am
3
Hi @Gijs – SystemInfo pasted below
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09002, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Evaluation, build 2023-10-31
License details: Cloud Zoo
Expires on: 4675756-12-14
Apple macOS Version 13.4 (Build 22F66) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro16,2
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel Iris Plus Graphics (1536 MB)
BenQ PD3200U (3840 x 2160 @ 30.00Hz)
USB devices
Generic: Mass Storage Device
Realtek: USB 10/100/1000 LAN
Generic: USB3.0 Card Reader
LaCie: Rugged THB USB 3.0
Fresco Logic, Inc: Generic Billboard Device
Alpha Imaging Tech. Corp.: Razer Kiyo
GenesysLogic: USB2.0 Hub
3Dconnexion: 3Dconnexion Universal Receiver
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Users/bob/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/maxwell_rhino.rhp "Maxwell for Rhino" 5.2.6.0
/Applications/Rhinoceros8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp "ShrinkWrap" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/PlugIns/export_STL.rhp "STL Export" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/PlugIns/import_STL.rhp "STL Import" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.0.23304.1002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.0.23304.9002
/Applications/Rhinoceros8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23304.9002
Gijs
(Gijs de Zwart)
November 13, 2023, 8:07am
4
hi @bobtato You are running a mac without any dedicated graphics card that has very little video ram, on an external monitor. I suspect this is at least part of the problem. Does the issue you have persist, if you run Rhino on the laptop screen only?
Or, when the montitor is connected, but the spacemouse is not, and you modify the view with, say, the trackpad, do you then see the same issue?
Gijs
(Gijs de Zwart)
November 13, 2023, 1:06pm
5
@bobtato thanks for reporting,
I could repeat it here with the trackpad.
RH-78273 View gets stuck in dynamic mode
bobtato
November 13, 2023, 2:48pm
6
I don’t usually use the computer’s internal monitor or trackpad, but this does seem to happen more often when the rendered view is larger, yes.
(SystemInfo doesn’t report it, but I use a bluetooth keyboard and mouse).
