View Cube in Rhino
Is there any added ViewCube for Rhino !?
If the answer is no, I suggest add it in the future.
Thanks.
Hello - there is no tool like this in Rhino, no.
Can you add it to wish list? It’s useful.
Rhino has MaxViewport for this and its far more sufficient in my opinion.
if you need something similar you can keep a floating window with Set View in your viewport with some fancy cars inside which have the same function as your cube, you can of course also replace the cars with your own word images if you want and even use the same cube images.
41
It’s a legitimate wish nonetheless, even if it’s not likely to be implemented too soon if at all.
https://mcneel.myjetbrains.com/youtrack/issue/RH-49681
Note that the viewport tabs also provide this functionality and you could also add the other 3 ortho view tabs (Bottom, Back, Left) to your default template if you like to have all of them available all the time.
Please add a ViewCube like Autodesks, that can also rotate the whole viewport.
Behavior:
No objects selected - Click a face sets view zooms extents
Objects selected - Click a face sets view zooms objects into view
Additional use, ALT click a face sets the view as a UCS (workplane) and changes snap depth to the plane, ALT double click to set back to the view or some other key combo to get back to the world view.
This doesn’t really cut it in 2025 like it did in 1995:
Based on Joshua Kennedy’s post in https://mcneel.myjetbrains.com/youtrack/issue/RH-49681
Iit will not happen until at least 2029 because the concept is patented by AutoDesk with the patent expiring in 2029:
An enhancement with the thumbnails displayed on the faces is patented with that patent expring in 2033:
David, not many companies take a patent on a ‘conceptual’ idea very seriously now do they?
List of applications with Viewcubes:
Altair Inspire
Shapr3D
Siemens SolidEdge & NX
Tekla Structural Designer
BricsCAD
ZWCAD
Hoops Visualize (graphics engine)
Open IFC Viewer
PTC Creo
Aveva E3D (its a sphere but still conceptually a navigational element.)
It doesn’t even have to look like Autodesk’s viewcube, just have to work like one. Here’s how Blender does it:
