My previous navigation plugin was removed from Food4Rhino after a patent notice. I redesigned it and would like to know if this version is acceptable (images attached).
Version A (image 1): three thin rings (XY, XZ, YZ). Click a ring to align the view, click again to flip 180°. Drag along a ring to rotate around its axis. Drag in the open space to orbit.
Version B (images 2–4): six buttons, as dots or hexagons (Top, Bottom, Front, Back, Left, Right). Click a button to align the view. No diagonal views.
Both versions:
No cube, and no selectable faces, edges, or corners.
The axis lines and the CPlane indicator are display-only. They cannot be clicked.
Every selectable control is a plain button: a ring, a dot, or a hexagon. Each runs one command.
Four arrows rotate the view by 45°. Two curved arrows are undo/redo of view history. Icons for CPlane, parallel/perspective, zoom extents, and home.
As far as I can tell, you have already been provided with a link to that document through several ways. One such public occasion:
Whether or not your plug-in is a patent infringement or not is a question that will only ever get answered fully in a meeting between your attorneys and theirs (use of plural here is intended), or, if they fail to resolve this, by a court. It’s your responsibility to check with them; not ours.
Apart from that, note that the title of that document states “indicator”.
This redesign was made after the plugin was removed from Food4Rhino, so that it has no cube and no selectable faces, edges, or corners.
I am not asking McNeel to decide whether it infringes. I understand that is my responsibility.
My question is only about Food4Rhino: can this redesigned plugin be published there, or will Food4Rhino not accept this kind of navigation gizmo at all?
And Food4Rhino is McNeel’s own site, so whether to host the plugin is McNeel’s decision, and I can’t ask Autodesk for that.
