Rhino ViewCube: Interactive 3D Navigation Cube for Rhino 8
ViewCube plugin for Rhino 8 to make viewport navigation and orientation faster and more intuitive.
Freecad style
Key Features:
  • 26-Zone Orientation: Click any face, chamfered edge, or corner to align the camera instantly.
  • Interactive Orbit: Click and drag directly on the cube to tumble/orbit the view smoothly.
  • Quick Tools:
    • Roll Arrows & Step Triangles: 90° roll and tilt around the current view.
    • Home Button: Return directly to the default framing/perspective.
    • Perspective / Parallel Toggle: Switch projection mode with one click (bottom-right mini-cube).
    • Zoom Extents: Frame your model geometry instantly (bottom-left button).
  • Customization (Right-Click Menu):
    • Switch between full face labels (FRONT, TOP, etc.) and large single letters (F, T, K, R…).
    • Dynamic scaling from 0.5× to 2.0× to fit high-DPI screens.
Commands:
  • ToggleViewCube — Show or hide the navigation cube.
  • ViewCubeSize — Adjust scale multiplier (0.5 to 2.0).
  • ViewCubeLabels — Toggle between Full names and Single-letter modes.
Navigating complex models and constantly adjusting the Construction Plane in a single maximized viewport.
Here is what it brings to your viewport:
1- 26-Zone Orientation & Free Orbit Instant click-to-snap for 6 primary faces, 12 beveled edges, and 8 corners, plus real-time click-and-drag camera tumbling.
2- ViewCube-Driven CPlane Alignment (Auto-CPlane) Switching views can now automatically reorient your working plane across 4 dedicated modes:
  • Off :Standard camera navigation.
  • Faces Only :Snaps grid to orthogonal planes (TOP, FRONT, RIGHT…).
  • All Zones :Aligns perpendicular to faces, edges, and corners.
  • Free Orbit :Automatically aligns the CPlane to your view plane on mouse release after a free drag!
3- Dynamic Axonometric Mini-Cube Cycle between Perspective, Isometric (35.26°), Dimetric (19.47°), Trimetric (25°), and Bird’s-Eye (45°) with 1 click. The mini-cube icon dynamically morphs its 3D geometry to reflect the active projection.
4- Dedicated Quick Tools
  • 90° curved roll ribbon arrows & directional step triangles
  • 1-click Home button to restore default framing
  • Dedicated Zoom Extents shortcut
  • Right-click menu for single-letter labels (T, F, R…) and dynamic UI scaling (0.5× to 2.0×)
Looke very interesting and can bring lot of F360 users to the Rhino side. Well done.
Is it available?
Very nice! :clap::clap::clap:
I would add an orient to object face feature that has the option to create a section view through the model - helps with drawing 2d sketches as you would in FreeCAD
Nice idea, i will add it
Thanks, still in validation process.
Saw you post this on LinkedIn and didn’t think you were going to share it so I vibe coded one up myself. I also made it change the shortcuts when it is installed to match SolidWorks view ports.
CTR+1: Front
CTR+2: Back, etc.
It isn’t as pretty as yours yet though.
@adel.albloushi
Section and orient to face added.
this looks very useful
amazing :folded_hands::folded_hands::folded_hands:
quick question: are you vibecoding it? nevertheless it’s very impressive
here’s another idea that i think will be useful for CAD pros: the ability to assign any of the views to any arbitrary viewport (or create a new viewport) by clicking any of the cube’s/gizmo’s handles or any set of object’s faces. this would be useful for scenarios when one would need to work in more than one viewport at the same time.
on the section: it would be useful if there was a option to set (via the context menu) the default section distance from view - minus values towards the viewer, positive values farther from the viewer.
Also, there should be a toggle to hide or show the clipping plane or section glyph by default
Mr Bean: Rowan Atkinson Waiting
Dog Crying Meme: Doggo Crys
im just gona communicate with gifs on every post now :joy:
I used gemini flash and argon, original project was created with python for Ingetrazo
I prefer don’t make it complicated too much specially with views and viewport.
you can already enable ‘Show in All Viewports’ in the right-click menu
These are already exist.
:grinning_face_with_smiling_eyes:
Food4Rhino usually validates submissions within one day, although sometimes it takes longer.
ah got it, looking forward trying it out
understandable
while we all understand how to do all that the traditional way (just like we know how to manage views)…
i was thinking more in terms of a quality of life / timesaver feature. For example, if i hold ctrl (or any other key) while clicking top/bottom/left/etc or an object face it would open a new viewport with that view. if i click again it would open yet another one, and so on. the viewport layout would arrange automatically.
regardless, thank for the awsome plugin. looking forward to trying it out
