View capture darkens objects
When I use _viewCaptureToFile (or _viewCaptureToClipboard) it significantly darkens the objects in view. Is there a way to fixt that and actually capture what’s in the view?
Thank you for your ideas
That might be due to the graphics card driver. I’d check if there is an update available from the manufacturer. Provide the results of your SystemInfo command and a sample 3dm file if you still need help.
Thank you for your reply. Please note that this happens on all our company computers regardless of age and hardware setup.
Rhino 7 SR31 2023-6-15 (Rhino 7, 7.31.23166.15001, Git hash:master @ 850d276b2d59d7e51843939e4cf674b356bcd354)
License type: Commercial, build 2023-06-15
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 2-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.49
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-2-2023
Driver Version: 31.0.15.2849
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:/Program Files/Tri D Technologies Inc/ExactFlat\ExactFlat.rhp “ExactFlat”
C:\Program Files\Tri D Technologies Inc\Monarch\Renderer.rhp “Monarch”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.31.23166.15001
example_file.3dm (3.7 MB)
Thanks, This appears to be due to the transparent background option. I’ve filed https://mcneel.myjetbrains.com/youtrack/issue/RH-76124 for the developers to look into it.
Just noticed the release target for Rhino 8.1. That is kind of sad since we bought R7 because of it´s capability to produce reasonable quality renders with metalic materials instantly (with view capture). Is there any chance this bud will be fixed in R7? If not can this be solved by any sort of workaround?
Thanks
the issue seems fixed in R7, was this intentional? Haha
Don´t know about R8 because I´ve lost access since the release.
But anyway, thanks for all the fish :slight_smile:
I was wrong - the issue isn´t fixed, but it has to do with ambient light. During view capture to file the ambient light turns from whatever to 0,0,0.
Hope this helps and really really really really hope this could be fixed in R7. Or at least if a suitable workaround could be provided. I don´t think the solution to a bug in something featured as an advancement in R7 should be buying R8. What is your view on the matter?
Thank you :slight_smile:
Hi @kral ,
I’ve added your request that any fix be added to a v7 service release as well. Typically the only reason it wouldn’t in a case like this is if there were a development reason that a change wouldn’t work there. I can’t say for sure though and I don’t set the release target myself, that is for the developer to determine based on how the code works.
You should be able to use the 90 day evaluation of Rhino 8 as well now but this is not a permanent solution for when this specific issue is fixed. It’s still open.
is there any progress on this issue? It´s been a while.
the lights are still off :confused:
there is still a major difference between transparent and nontransparent background.
I would welcome any solution or workaround.
*Bump ..
This continues in Rhino 8, is it by any chance in Rhino 9 too?
I just checked and it’s in the v9 WIP too. I added your comment about ambient light to the bug report as well and asked the developer for a status update. Can you leave the ambient color as black and adjust scene lighting instead? That appears to allow the transparent background option without impacting brightness.
Thank you so much. This works perfectly. :slight_smile:
RH-76124 is fixed in Rhino 8 Service Release 30
