Hi! I am trying to draw the lines for each vertical column of points, which actually are the vertices of different polylines. However, It gets all messed up when I try to use polyline and even flip matrix. What is the best way to organize the lists in order to achieve these vertical lines for every vertex column? Thank you!!!
Seems like connecting corner vertices of the floors which have the same area is not a difficult problem. BTW, How do you plan to connect between floor plans that have different number of corner vertices with vertical lines ?
I don’t think that the polylines should connect all the way through. Is there any way to recreate the polylines from those lines end points? I tried it but the polyline goes all the way trhough to the last and it shoud actually remain a coplanar polyline.
