s.carta
(S Carta)
1
I am trying to connect a set of points with polylines in vertical columns.
I’ve tried seeveral methods but cannot seem to organise the data properly.
This is the closest I can get, but I need a line per column (as highlighted).
Any help would be great! thanks.
s.carta
(S Carta)
2
Theater seats? And you want to find rows?
inno
4
proximity2d can get you at this stage, don’t know if those gaps are ok or should be filled
lines_through_columns_re.gh (20.8 KB)
Very nice! I would add the white group (below) to get the rows in order:
P.S. A smaller value (~1000) on the PGroups ‘D’ input will separate the four sections on the back row.
s.carta
(S Carta)
7
@Joseph_Oster yes, that’s right!
s.carta
(S Carta)
8
@inno it works like a charm! Thanks very much. (gaps are where strucutral elements are, so all good). Cheers!
s.carta
(S Carta)
9
@HS_Kim fantastic! many thanks. (it connects all points in each row with a single line). Brilliant.
s.carta
(S Carta)
10
excellent! many thanks for the prompt reply and halp @Joseph_Oster
inno
11
this idea of using non-uniform scale made my brain explode
I would never have thought about that, not even in 10 years
