Vertical cladding with random widths
Hi!
I’m new to grasshopper and am trying to create a script to create vertical cladding patterns for a facade I’m working on. I have tried different approaches but not been able to create what I’m looking for so I’ll try here:
I want to have three different vertical timber elements arrayed along my facade.
Each panel has the same depth,12mm. Each panel has a height of 3000mm, and I want each panel to have a width of either 70mm, 100mm or 120mm, and have these placed along my facade in a random order with a distance between them of 10mm.
I want to being able to use random/seed input to generate different facade designs.
Is anyone able to help me achieve this? Or point me in a direction of a tutorial or similar?
Below is a photo of what I’m trying to create.
one way could be:
timber_001.gh (11.2 KB)
random divide curve.gh (15.4 KB)
Thank you! This was exactly what I needed. :slight_smile:
I couldn’t get the script to work with my original problem, as there was no set 1cm distance parameter and I needed 3D geometry not just lines, but thank you anyway! :slight_smile:
