Vertex crease Broken?
Hi All,
I’m using BETA 9.0.26272
In this version you can create a _SubDPlan with SubDCorners and you can also remove the crease.
But adding a crease to a vertex is not possible, at least the same way that works in V8. Any idea of what is happening?
ctrl+shit drag select the vertex you want and then run the crease command.
working here in latest beta -
Hi Kyle, thanks for the replay.
Your workflow works, but apparently there was another way in V8 that also worked, and now doesn’t.
in V8 if you select a control point after turning point on with F10 in smooth mode, you can add a crease to one vertex. This is not possible in V9, is this intentional?
interesting… you can crease a surface point (vertex) , but not a control cage point. (cv)
feels buggy…
RH-99243 crease subd does not work on cv’s
RH-99243 is fixed in Rhino BETA
