SUB-D question > hard crease behavior is unexpected
I am trying to get a hard crease at the end of a 2-D surface. It won’t work and I get the messsage ‘No changes made’
I’m pretty sure this worked for me in the past. Is there a setting that may have been turned off?
Alerting @theoutside and @BrianJ
Assuming that this is normal behavior, I discovered a fiendishly clever hack-around to get the geometry behaving.
This is an extra few steps, but please comment if there is a better way to achieve a sharp crease on a perimeter edge. I’d love to know what is up.
You can use UnweldVertex command like this:
The Crease command does the same when vertices are selected instead of edges.
select the vertexes of that edge and crease them.
“creases” need a corresponding face to actually compute the crease.
so a naked edge, you can only crease the vertexes…
Hey @kyle and @Mahdiyar
You two nailed it. Thank you!
I never noticed this before, but using the vertices works for what I want … and better than my hack.
you only need to select the corners… the center vert is ignored.
Wow, super cool. Thanks again.
