Hello everyone, I am calling on the forum following initial help from you. The project is to model the velodrome stadium in Marseille. The roof is already modeled but some parameters need to be changed. I provide you with the documents to understand the building and the roof grasshopper file. Thanks!
rf.gh (54.1 KB)
You could have just replied in the thread where you got help previously - it seems you didn’t manipulate anything
*Edit: maybe ‘study’ model was a bad name if it was not going to be studied lol
I’ll wait for someone to intervene
In the meantime, if you pay attention to the original example, what matters is that there are two guide curves that create the ruled surface on which the panels are generated.
You can open the example (same one you’re posting here) and identify said curves:
You can replace these imputs with your own curves - you could even draw them manually in Rhino to advance the ‘study’ and know what’s going on
Thank you sincerely for your response. I apologize if my communication approach wasn’t optimal. I take note of your suggestion and will make sure to be more attentive in the future.
Once again, thank you very much for your patience and assistance.
You’re welcome - no problem.
The intent is that you get proper help
Come back with questions if you hit a wall.
@martinsiegrist (sorry to bug you) are you able to ‘merge’ this topic with the previous one?
I don’t have permission to merge topics.
Hello, thanks to your previous work, I was able to modify the initial model. I think I’m not very far from reality anymore.Thank you again for the help provided.
ps: if you want to see the result you have to add the initial point
toit velodrome.gh (35.7 KB)
