Varying the displacement pattern across the face of a subd object
Below shows how I’m sculpting the shard of an iceberg face based on an image. I’ll be sculpting others. I don’t need them to be an exact match to reality, but I’d like to get closer. I’ve accomplished adjustable horizontal grooves by tweaking Rhino’s Turbulence Texture - I’ll continue to tweak this but the result’s always more or less consistent across the entire surface. The real world horizontal texture gives way to more rubbled random surfaces toward the bottom, but to emulate this I’m not sure how - or whether - there’s a way to transition from one displacement texture to another across an object without creating a particular varying texture image for every different shard. Thoughts welcome. (I know I could extract the mesh and edit certain areas, but I need to keep the object editable as a subd.)
After some searching I’ve found citations on the forum indicating that displacement mapping doesn’t work on subd objects. And yet I have done so without incident over the last couple of days. I’m looking forward to a discussion with tech support soon.
@djhg I can’t help very much here, but anyone who can help will very likely start by asking for an example file showing where you are stuck or where something is not working the way it should. Could you upload an example file please?
The file you are working on is best, or a similar example showing the issue but on simpler, non private, geometry. If none of this works for you, you can also upload a file privately to tech support here: https://www.rhino3d.com/upload
Maybe @Jussi_Aaltonen knows more about textures and displacement on SubDs?
Thanks Pierre. I’ll upload a file to that link. Done.
It’s worth mentioning that the path I’m considering is where secondary displacement textures are substituted for the colours in a primary displacement texture. I’m not sure it’s working properly on any type of object, and I’ve become wary of displacing off of a subd at all since I’ve recently seen questions about the feasibility of that.
Here are the results I got from your file and another SUbD test model:
Displacement on the SubD object in the file you sent:
I was also testing with this:
dispalacementV8.3dm (482.5 KB)
Thankyou Scott. That looks like what I’ve sent. I’m keeping the polygon count low for now.
I’m in R7 at the moment. (I’ve got R8 as of this weekend but I haven’t activated it. I need to test it with Va)
I’d like to know if displacement mapping is reliable enough on a sub D as it’s continually edited, to create a stable object and a displaced render mesh which is constantly updating through the object’s edits, and which will be at the final stage be output for 3d printing.
I am also trying to run the texture across the objects like this:
The trick is to use a material that can be planar mapping across both objects so they match.
Thanks Scott.
Maybe using the image for a texture would be a good idea. My initial efforts didn’t work too well, but I was using the full image, but on a shard-by-shard basis it might work.
But more importantly, is displacement on subd objects stable?
By using a material and then mapping that with mapping, it should be stable. I should say the position of the displacement will be stable across the multiple objects.
But, and this is specifically related to displacement, the effect of displacement will be affected by the size of the render mesh on the object. So if the size of the render mesh on the subd is different then the larger plane then they can displace quite differently.
As an example here, the plane may be meshed much different then the subD:
And that will lead to quite a different displacement of the render mesh between those two objects. Normally in this case I would increase the plane mesh object to have a tighter mesh.
Also, the displacement mesh probably Needs to be high contrast and black to white. Then that will give the most control possible:
Displacement is complicated, there are a lot of settings that effect it.
Thanks Scott. I’m creating a separate map for each shard and yes, high contrast helps. I might be getting the hang of it.
But meanwhile I have an anomaly to report. any texture I attempt to import into the texture panel does not show up there. It will only show up there if I import it directly into the displacement panel.
