VARQ 3.13 printing bug - meshes on Hidden
Here’s one more of those annoying ‘find only after you have everything ready for printing’ bugs.
View in Rhino Layout (viewmode Hidden)
Print result
Quess which geometries are meshes…
Might be relevant that all the geometry is worksessioned.
@fsalla Let me know if you need the files
kuva
Ok, I was able to narrow it down a bit.
The printing error occurs, when there’s a Linked (Active or Referenced doesn’t matter) block that contains a mesh. Works after Embedding the block or exploding.
Worksession is irrelevant in this case.
Edit: Meshes are irrelevant. Just needs to be a Linked block.
Hi Toni, the option to print external files to vector output using the Hidden display mode is not consistent if the blocks are not inserted as “Embedded and linked”. I hope in a future we will support also “Linked” and “Embedded” blocks
Thanks for the clarificarion. Noted, and luckily there’s a simple workaround.
