PDF Printing - Technical Mode, Missing and False Objects
Had some spare time, playing around with line weight standards, and took one of my previous assemblies into a new file to tweak.
I’m noticing some missing lines when printing, and some areas where things are printing that just don’t exist in the file.
I’m trying out a custom display mode that’s Technical but with no hidden lines showing, but the same artifacts are happening in standard Pen.
Artifacts don’t show up in the detail view, but show up on Print Preview, and on final print.
Lwt Testing.3dm (11.6 MB)
Technical, No Hidden Lines, TB Rem’d.pdf (254.3 KB)
Blocks are all embedded McMaster-Carr parts, originally downloaded as STEP, saved as 3DM with all options as “By Parent”.
Print settings are set to Vector, which I’d prefer to keep if possible…
Any thoughts of where I might be going wrong?
System Info
Rhino 8 SR17 2025-2-25 (Rhino 8, 8.17.25056.13001, Git hash:master @ 8d674f13b6b22b7c0498dd9ff031d36e49dcd349)
License type: Commercial, build 2025-02-25
License details: Cloud Zoo
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25056.13001
C:\Users\ssommerville\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25056.13001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.17.25056.13001
Updated to latest Version 8 SR17 (8.17.25063.13001, 2025-03-04) - section outline artifact (pulley cross section on the right) is gone; edges still missing.
Technical, No Hidden Lines, TB Rem’d, update.pdf (252.3 KB)
Hi Scott -
Thanks.
We’ve had variations of this on the list for a while (e.g. RH-79540) but I’ve dug a bit more into this one and created a somewhat more specific ticket - RH-86404 Print: Fake2D Misses Silhouette on Cylindrical Block
Note that either exploding those blocks, or block editing and shrinking the surfaces makes this issue go away.
Thanks Wim. Hopefully this gets resolved - vector printing seems to be getting better and better, and it’s wonderful to have.
Exploding the blocks kind of defeats the purpose of using them, I think.
Re: Shrinking the surfaces - you mean taking the 0.250" cylinder and making it something like 0.249"?
Edit: oh, I see - ShrinkTrimmedSrfToEdge makes it work. Interesting! Maybe that’s something I should do with all of my blocks with round/cylindrical features from now on…
Hi Scott -
I agree.
Yes, I’m afraid so, for the time being…
No worries. It shouldn’t affect the end result geometry of the block at all, as I understand it, and it’s a relatively quick and easy thing to do, if it gets the results I’m looking for when printing.
Thanks!
Hi Scott -
Do you happen to still have that original STEP file laying around?
I didn’t (I don’t typically keep the STEP), but I just redownloaded it.
92865A544_NO THREADS_Medium-Strength Grade 5 Steel Hex Head Screw (1).STEP (90.1 KB)
Thanks, Scott!
No worries. Let me know if there’s anything else I can provide. Blocks, models, display settings, etc…
